13 years agoThe error is pretty self-explanatory; you have fed your PLL from a pin that is not a dedicated clock pin that can be directly connected to the PLL, hence the jitter performance may be compromised.
The solution is to use a clock source that the PLL is happier with. Cheers, Dave
