What is: altera_mem_if_sequencer_cpu_no_ifdef_params_sim_cpu_inst.tr file and how to use it?
- 3 years ago
Hi Tom,
I can see which file that you are mentioning and it's a file that has been generated when running the simulation. This file actually captures the transaction of the simulation. So the size is depends on the transaction.
If you want to disable this file, you can check in the testbench file located in the submodules folder.
The name of the testbench file is altera_mem_if_sequencer_cpu_no_ifdef_params_sim_cpu_inst_test_bench.v.
In the testbench file, you can scroll down until line 694 to 704. These lines will create the file and write the transactions into the file.
By disabling lines 694 to 704, the file will not generated.
Adzim
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
