9 years agoWhat information about .aocx files?
I don't understand What information about .aocx files?Wheather it only contains of opencl kernel or both platform and opencl kernel? Wheather the platform and opencl kernel are programmed in FPGA separately or not ?
If by "platform" you mean the host code, it runs on the CPU. The aocx file only contains the kernel code. The host code has to be compiled separately with a standard c/c++ compiler and will have its own standard x86/x64/Arm binary.
--- Quote Start --- If by "platform" you mean the host code, it runs on the CPU. The aocx file only contains the kernel code. The host code has to be compiled separately with a standard c/c++ compiler and will have its own standard x86/x64/Arm binary. --- Quote End --- The "platform" is not meaning the host code,which means the hardware we develop in verilog HDL . I want to know wheather the .aocx files which contains of both opencl kernel and the target board or not .
