16 years agoDear FvM,
thank you for your kind suggestions. I tried to rewrite everything according to your suggestions and got my project compiled, however I am still not sure that everything is ok. I got very impressive Fmax counts for several clocks of my design: 438MHz for InReady and 153MHz for the internal clock which is 4 times demux of InReady, so, I need at least 100MHz. Indeed I have two designs, one is running with InReady clocked at 200MHz and one other slightly differ with more wider reg [27:0] InData running at 400MHz clock. What I cannot understand right now in my Quartus compilation, is the following: I allocate reg [63:0] RingData [0:8191], so, it is 512KBits, however, in "Flow Summary" I used zero bits. Would enybody comment me where my RingData and TimeStep arrays was allocated? In RTL it is marked as sync_ram, but if the internal Cyclone 3 memory of 608K were used, why the Flow Summary has zero bits of usage. I am attaching complete code of this project, RTL, Fmax and Flow summaries. Sincerely, Ilghiz
module My_First_Project (InData, InReady, OutClock, OutData);
parameter MaxK=8;
parameter BLKSIZE=1024;
parameter MaxN=MaxK*BLKSIZE;
input InData;
input InReady, OutClock;
output OutData;
reg OutData;
reg signed LD0, LD1, LD2, LD3, LD4;
reg signed PE, NE;
reg DeMuxCounter;
reg H00, H01, H02, H03, H04, H05, H06, H07, H08, H09;
reg H10, H11, H12, H13, H14, H15, H16, H17, H18, H19;
reg H20, H21, H22, H23, H24, H25, H26, H27, H28, H29;
reg H30, H31, H32, H33, H34, H35, H36, H37, H38, H39;
reg SumS1, SumS2;
reg LevelS1, LevelS2;
reg signed x1, x2, x3, x4;
reg y1, y2, y3, y4, yy1, yy2, yyy, LS1, LS2;
reg z1, z2, z3, z4, zz1, zz2, zzz;
reg NadoT;
reg CurTime;
reg RingData ;
reg TimeStep ;
reg BeginPos;
reg EndPos;
reg CurShiftData;
reg CurPos;
reg EndPosSw;
initial
begin
LD4<=0;
CurTime=0;
SumS1=1;
SumS2=1;
LevelS1=1;
LevelS2=1;
NadoT=0;
DeMuxCounter=0;
BeginPos=0;
EndPos=0;
CurPos=79;
EndPosSw=1;
end
always @(posedge InReady)
begin
PE <= {PE, InData};
end
always @(negedge InReady)
begin
NE <= {NE, InData};
DeMuxCounter<=DeMuxCounter+1'b1;
end
always @(posedge DeMuxCounter)
begin
if(NadoT)
begin
RingData=H39;
NadoT=NadoT-1'b1;
if(BeginPos==0) TimeStep]=CurTime;
BeginPos=BeginPos+1'b1;
end
begin
LD0<=LD4;
LD1<={PE, NE, PE, NE, PE, NE, PE, NE,
PE, NE, PE, NE, PE, NE, PE, NE};
LD2<={PE, NE, PE, NE, PE, NE, PE, NE,
LD3<={PE, NE, PE, NE, PE, NE, PE, NE,
LD4<={PE, NE, PE, NE, PE, NE, PE, NE,
end
begin
{H00, H01, H02, H03, H04, H05, H06, H07, H08, H09,
H10, H11, H12, H13, H14, H15, H16, H17, H18, H19,
H20, H21, H22, H23, H24, H25, H26, H27, H28, H29,
H30, H31, H32, H33, H34, H35, H36, H37, H38, H39} <=
{LD1, LD2, LD3, LD4,
H30, H31, H32, H33, H34, H35, H36, H37, H38};
x1<=LD0-LD1;
x2<=LD1-LD2;
x3<=LD2-LD3;
x4<=LD3-LD4;
y1<=LD1*LD1;
y2<=LD2*LD2;
y3<=LD3*LD3;
y4<=LD4*LD4;
SumS1<=SumS1-(SumS1>>3);
SumS2<=SumS2-(SumS2>>3);
LS1<=LevelS1-(LevelS1>>3);
LS2<=LevelS2-(LevelS2>>3);
CurTime<=CurTime+1;
end
begin
z1<=x1*x1;
z2<=x2*x2;
z3<=x3*x3;
z4<=x4*x4;
yy1<=y1+y2;
yy2<=y3+y4;
end
begin
zz1<=z1+z2;
zz2<=z3+z4;
yyy<=yy1+yy2;
end
begin
zzz<=zz1+zz2;
SumS1<=SumS1+(yyy>>5);
end
begin
SumS2<=SumS2+(zzz>>5);
end
begin
if(SumS1>=LevelS1 && SumS2>=LevelS2)
begin
LevelS1<=LS1+(SumS1>>5);
LevelS2<=LS2+(SumS2>>5);
NadoT<=NadoT+3072;
end
end
end
always @(OutClock)
begin
begin
{CurShiftData, OutData}<=CurShiftData;
end
if(CurPos) CurPos<=CurPos-1'b1;
else
begin
CurPos<=79;
CurShiftData<=EndPos;
if(EndPos==0 && EndPosSw)
begin
CurShiftData=TimeStep];
EndPosSw=0;
end
else
begin
CurShiftData=RingData;
EndPosSw=1;
EndPos=EndPos+1'b1;
end
end
end
endmodule
