10 years agoWhat happened to vhdl.org?
I was looking for the fixed-point libraries for fixed-point and floating-point arithmetic's from David Bishop, they used to be here http://www.vhdl.org/fphld/vhdl.htmbut now the website is gone. Any ...
10 years agoAfaik, the 2008 libraries are only included in prime pro - otherwise you have to provide the code as part of your project. But quartus has worked just fine with the compatability packages since at least 2009, where I was using it to infer multipliers and rams from ufixed and sfixed.
Using numeric_std is actually the "normal" way to do it. fixed_pkg actually re-invents the wheel and is hardly used. numeric_std has been around since 1993 and has arithmatic, resize() etc. But yes, you have to track the integer/fraction separation yourself, but it's not that hard to do - it just takes a little thinking. And to be fair, if you ever have to use the altera lpm library (for a divider for example), you'll have to convert everything to slv anyway.
