9 years agoWhat does the "work item" stand for in FPGA?
Hello everyone! There has been a problem puzzling me since I come into contact with the opencl for FPGA. As I know , the "work item"--one of the basic term in opencl model, correspond to a proc...
9 years agoFPGA hardware is not fixed and the resulting circuit can be vastly different depending on the kernel. Regardless of the kernel programming type (NDRange or single work-item), one or multiple pipelines are generated by Altera's compiler and in each case, either the work-items (for NDRange) or loop iterations (for single work-item) are considered as inputs to the pipeline(s), and are issued in some order and interval decided by the compiler. You can think of single work-item kernels as NDRange kernels that have been wrapped inside a for loop from 0 to global_size; in other words, in single work-item kernels, the loop iterations play a role similar to work-items in NDRange kernels.
