13 years agoThanks, both of you. But I found another thing in my following code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity signed_adder is Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; Q : buffer STD_LOGIC_Vector (7 downto 0)); -- signed end signed_adder; architecture Behavioral of signed_adder is SIGNAL temp : STD_LOGIC_VECTOR (7 downto 0); begin temp<=X"15"; process (clk) begin if clk'event and clk='1' then if (rst='1') then Q<=8D"12"; else Q<=Q+1; end if; end if; --Q<=temp; end process; end Behavioral; Why in the code"Q<=Q+1;", It can work that 1 without double quote?
