Altera_ForumHonored Contributor12 years agoWeirdest thing - MAX3000A simulation I think I'm going crazy... I created a simple project for MAX3000A (schematic file, part of the schematic is attached) and tried to simulate in ModelSim - SE. https://www.alteraforum.com/forum/...Show Moremultiple-attachments.zip81 KB
Altera_ForumHonored Contributor12 years agoModelsim SE doesn't understand Altera schematic entry. Which RTL netlist are you simulating?
Recent DiscussionsTiming analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
