12 years agoHi guys,
All good points ... keep in mind the original comment --- Quote Start --- a signal from a button press --- Quote End --- A button should be debounced, and that would typically be done with logic that uses a clock, and hence it would be "good design practice" to also use a clock for the multiplier. Cheers, Dave
