9 years agoWeird SignalTap behaviour
Trying to solve a mystery, but after several days ran out of thoughts :( Needed to connect to SignalTap around 100 (probably, a bit less) signals, and at some moment got very strange picture (...
9 years agoI agree that the signal tap picture isn't well understandable at first sight.
I presume that the acquired signal are clean PLL outputs, without glitches. The only way to get the high or low level corrupted outside the actual level transitions is that the 210 MHz signal tap logic doesn't achieve correct timing closure. This can happen under circumstances for a wrongly constrained design that tries to fix timing violation in one place and newly generates others instead. What I usually do with signal tap designs is to specify false paths for signals into the signal tap logic (or equivalent clock groups for the signal tap clock) that can't achieve timing closure by nature, if not already achieved by general design constraints. This way I avoid useless timing optimizations and allow timing analysis to focus on the actual critical paths.
