16 years ago
Weird shift register behavior
I have a setup with two shift registers and a ram megafunction. All interfaces are 1 byte. The shift register takes in a serial stream, and then when writeEN is asserted, it parallel loads its data into RAM, and when readEn is asserted, the data is read out of an address in RAM and parallel loaded onto another shift register, and shifted out serially. The second shift register is acting strange in that its output isn't following the enable signals.
Here's what I have:
library ieee;
use ieee.std_logic_1164.all;
entity framestore is
	port
		clk,reset : in std_logic;
		input: in std_logic;
		writeEN : in std_logic;
		readEN: in std_logic;
		rwAddress: in std_logic_vector(9 downto 0);
		output : out std_logic;
		writing : out std_logic_vector(7 downto 0);--test signal to keep track of what I write to memory
		reading : out std_logic_vector(7 downto 0)--test signal to see what I read from memory
end framestore;
architecture structure of framestore is
	signal toRam: std_logic_vector(7 downto 0);
	signal fromRam: std_logic_vector(7 downto 0);
	COMPONENT rshift1byte IS --this is the first shift register, that has serial in, parallel out to ram
	PORT
		aclr		: IN STD_LOGIC ;
		aset		: IN STD_LOGIC ;--sets to 0's
		clock		: IN STD_LOGIC ;
		shiftin		: IN STD_LOGIC ;
		q		: OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
	END COMPONENT;
	COMPONENT ram1port IS
	PORT
		address		: IN STD_LOGIC_VECTOR (9 DOWNTO 0);
		clken		: IN STD_LOGIC  := '1'; --this enable is for the output port
		clock		: IN STD_LOGIC  := '1';
		data		: IN STD_LOGIC_VECTOR (7 DOWNTO 0);
		wren		: IN STD_LOGIC ;
	END COMPONENT;
	COMPONENT rshift1byteout IS --this is the second shift register which has parallel in, serial out
	PORT
		aset		: IN STD_LOGIC ; --sets to 0's
		load		: IN STD_LOGIC ;
		shiftout		: OUT STD_LOGIC
	END COMPONENT;
begin
	shiftin: rshift1byte port map(reset,reset,clk,input,toRam);
	ram: ram1port port map(rwAddress,readEN,clk,toRam,writeEN,fromRam);
	shiftout: rshift1byteout port map(reset,reset,clk,fromRam,readEN,output);
reading<=fromRam;
writing<=toRam;
end structure;
reading and writing signals give the correct values, but they don't get shifted like they should in the output
Thanks!
    I wonder if it has to do with lpm_shiftreg doing arithmetic shifts? (padding with 1's) instead of padding with 0's
    The RAM read timing may be incorrect. You don't show the RAM parameters, so the timing can't be seen from your code. Did you watch the design in Quartus simulator? I guess, the problem is obvious then.
    Yes, I've simulated. The problem isn't with the RAM timings because the values are where they are supposed to be (or at least, the signals that I put in to catch the values that get written/read from RAM have the right values at the right times), I think the problem is that second shift register. It doesn't have an serial input because I don't want it to but maybe I should be shifting in zero constantly.
    I was right. The problem had to do with the contents of the shift register if it didn't have a serial input. I gave it a serial input and just pump in zeros and it works. Thanks guys
