16 years ago
Weird FIFO compiler error
I have an interesting error. I have a block diagram that I'm using to connect some symbols together that I've designed.
Here's an image of part of my block diagram:
http://img134.imageshack.us/img134/977/weirdz.jpg
I have a 4 bit output signal that comes from the block on the left and goes into the block on the right. I also have a 1 bit valid signal that does the same. Through trial an error I've found that if I take away that dangling wire, I get a compiler error that says:
Error: WYSIWYG primitive "transmitinterface:inst11|fifo1to4:validbit|dcfifo_mixed_widths:dcfifo_mixed_widths_component|dcfifo_ecg1:auto_generated|altsyncram_sl61:fifo_ram|ram_block5a0" has mismatched parameters for port Port A, Data In
Here's the code for transmitinterface
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity transmitinterface is
	port
		rdclk,wrclk,reset: in std_logic;
		input: in std_logic_vector(3 downto 0);
		validin: in std_logic_vector (0 downto 0);
		validout: out std_logic;
		output : out std_logic_vector(15 downto 0)
end transmitinterface;
architecture structure of transmitinterface is
	signal hold : std_logic_vector(3 downto 0);
	component fifo4to16 is
	PORT
		aclr		: IN STD_LOGIC  := '0';
		data		: IN STD_LOGIC_VECTOR (3 DOWNTO 0);
		rdclk		: IN STD_LOGIC ;
		rdreq		: IN STD_LOGIC ;
		wrclk		: IN STD_LOGIC ;
		wrreq		: IN STD_LOGIC ;
		q		: OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
	end component;
	component fifo1to4 is
	PORT
		data		: IN STD_LOGIC_VECTOR (0 DOWNTO 0);
		q		: OUT STD_LOGIC_VECTOR (3 DOWNTO 0)
	end component;
begin
	inputbits: fifo4to16 port map(reset,input,rdclk,'1',wrclk,'1',output);
	validbit: fifo1to4 port map(reset,validin,rdclk,'1',wrclk,'1',hold);
	validout <= hold(3) OR hold(2) OR hold(1) OR hold(0);
end structure;
You can see that I use a fifo that I made, fifo1to4, the one displayed in the compiler error. Everything looks right to me though.
Here's the code for fifo1to4:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY fifo1to4 IS
	PORT
END fifo1to4;
ARCHITECTURE SYN OF fifo1to4 IS
	SIGNAL sub_wire0	: STD_LOGIC_VECTOR (3 DOWNTO 0);
	COMPONENT dcfifo_mixed_widths
	GENERIC (
		intended_device_family		: STRING;
		lpm_numwords		: NATURAL;
		lpm_showahead		: STRING;
		lpm_type		: STRING;
		lpm_width		: NATURAL;
		lpm_widthu		: NATURAL;
		lpm_widthu_r		: NATURAL;
		lpm_width_r		: NATURAL;
		overflow_checking		: STRING;
		rdsync_delaypipe		: NATURAL;
		underflow_checking		: STRING;
		use_eab		: STRING;
		write_aclr_synch		: STRING;
		wrsync_delaypipe		: NATURAL
	PORT (
			aclr	: IN STD_LOGIC ;
			q	: OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
	END COMPONENT;
BEGIN
	q    <= sub_wire0(3 DOWNTO 0);
	dcfifo_mixed_widths_component : dcfifo_mixed_widths
	GENERIC MAP (
		intended_device_family => "Cyclone II",
		lpm_numwords => 256,
		lpm_showahead => "OFF",
		lpm_type => "dcfifo",
		lpm_width => 1,
		lpm_widthu => 8,
		lpm_widthu_r => 6,
		lpm_width_r => 4,
		overflow_checking => "ON",
		rdsync_delaypipe => 4,
		underflow_checking => "ON",
		use_eab => "ON",
		write_aclr_synch => "OFF",
		wrsync_delaypipe => 4
	PORT MAP (
		wrclk => wrclk,
		rdreq => rdreq,
		aclr => aclr,
		rdclk => rdclk,
		wrreq => wrreq,
		data => data,
		q => sub_wire0
END SYN;
When I click on the compiler error it takes me to this code though:
FUNCTION cycloneii_ram_block (clk0, clk1, clr0, clr1, ena0, ena1, portaaddr, portaaddrstall, portabyteenamasks, portadatain, portawe, portbaddr, portbaddrstall, portbbyteenamasks, portbdatain, portbrewe)
WITH ( CONNECTIVITY_CHECKING, DATA_INTERLEAVE_OFFSET_IN_BITS, DATA_INTERLEAVE_WIDTH_IN_BITS, DONT_POWER_OPTIMIZE, INIT_FILE, INIT_FILE_LAYOUT, init_file_restructured, LOGICAL_RAM_NAME, mem_init0, mem_init1, MIXED_PORT_FEED_THROUGH_MODE, OPERATION_MODE, PORT_A_ADDRESS_WIDTH = 1, PORT_A_BYTE_ENABLE_MASK_WIDTH = 1, PORT_A_BYTE_SIZE, PORT_A_DATA_OUT_CLEAR, PORT_A_DATA_OUT_CLOCK, PORT_A_DATA_WIDTH = 1, PORT_A_DISABLE_CE_ON_INPUT_REGISTERS, PORT_A_DISABLE_CE_ON_OUTPUT_REGISTERS, PORT_A_FIRST_ADDRESS, PORT_A_FIRST_BIT_NUMBER, PORT_A_LAST_ADDRESS, PORT_A_LOGICAL_RAM_DEPTH, PORT_A_LOGICAL_RAM_WIDTH, PORT_B_ADDRESS_CLOCK, PORT_B_ADDRESS_WIDTH = 1, PORT_B_BYTE_ENABLE_CLOCK, PORT_B_BYTE_ENABLE_MASK_WIDTH = 1, PORT_B_BYTE_SIZE, PORT_B_DATA_IN_CLOCK, PORT_B_DATA_OUT_CLEAR, PORT_B_DATA_OUT_CLOCK, PORT_B_DATA_WIDTH = 1, PORT_B_DISABLE_CE_ON_INPUT_REGISTERS, PORT_B_DISABLE_CE_ON_OUTPUT_REGISTERS, PORT_B_FIRST_ADDRESS, PORT_B_FIRST_BIT_NUMBER, PORT_B_LAST_ADDRESS, PORT_B_LOGICAL_RAM_DEPTH, PORT_B_LOGICAL_RAM_WIDTH, PORT_B_READ_ENABLE_WRITE_ENABLE_CLOCK, POWER_UP_UNINITIALIZED, RAM_BLOCK_TYPE, SAFE_WRITE)
RETURNS ( portadataout, portbdataout);
--synthesis_resources = M4K 1
OPTIONS ALTERA_INTERNAL_OPTION = "suppress_da_rule_internal=r105;OPTIMIZE_POWER_DURING_SYNTHESIS=NORMAL_COMPILATION";
SUBDESIGN altsyncram_sl61
	aclr1	:	input;
	address_a	:	input;
	address_b	:	input;
	addressstall_b	:	input;
	clock0	:	input;
	clock1	:	input;
	clocken1	:	input;
	data_a	:	input;
	q_b	:	output;
	wren_a	:	input;
VARIABLE
	ram_block5a0 : cycloneii_ram_block
		WITH (
			CONNECTIVITY_CHECKING = "OFF",
			DATA_INTERLEAVE_OFFSET_IN_BITS = 1,
			DATA_INTERLEAVE_WIDTH_IN_BITS = 1,
			LOGICAL_RAM_NAME = "ALTSYNCRAM",
			MIXED_PORT_FEED_THROUGH_MODE = "dont_care",
			OPERATION_MODE = "dual_port",
			PORT_A_ADDRESS_WIDTH = 8,
			PORT_A_DISABLE_CE_ON_INPUT_REGISTERS = "off",
			PORT_A_FIRST_ADDRESS = 0,
			PORT_A_FIRST_BIT_NUMBER = 0,
			PORT_A_LAST_ADDRESS = 255,
			PORT_A_LOGICAL_RAM_DEPTH = 256,
			PORT_A_LOGICAL_RAM_WIDTH = 1,
			PORT_B_ADDRESS_CLOCK = "clock1",
			PORT_B_ADDRESS_WIDTH = 6,
			PORT_B_DATA_OUT_CLEAR = "clear1",
			PORT_B_DATA_OUT_CLOCK = "clock1",
			PORT_B_DATA_WIDTH = 4,
			PORT_B_DISABLE_CE_ON_INPUT_REGISTERS = "on",
			PORT_B_DISABLE_CE_ON_OUTPUT_REGISTERS = "off",
			PORT_B_FIRST_ADDRESS = 0,
			PORT_B_FIRST_BIT_NUMBER = 0,
			PORT_B_LAST_ADDRESS = 63,
			PORT_B_LOGICAL_RAM_DEPTH = 64,
			PORT_B_LOGICAL_RAM_WIDTH = 4,
			PORT_B_READ_ENABLE_WRITE_ENABLE_CLOCK = "clock1",
			RAM_BLOCK_TYPE = "AUTO"
	address_a_wire	: WIRE;
	address_b_wire	: WIRE;
BEGIN
	ram_block5a.clk0 = clock0;
	ram_block5a.clk1 = clock1;
	ram_block5a.clr1 = aclr1;
	ram_block5a.ena0 = wren_a;
	ram_block5a.ena1 = clocken1;
	ram_block5a.portaaddr = ( address_a_wire);
	ram_block5a.portadatain = ( data_a);
	ram_block5a.portawe = wren_a;
	ram_block5a.portbaddr = ( address_b_wire);
	ram_block5a.portbaddrstall = addressstall_b;
	ram_block5a.portbrewe = B"1";
	address_a_wire = address_a;
	address_b_wire = address_b;
	q_b = ( ram_block5a.portbdataout);
END;
--VALID FILE
Please help.
1 Reply
    I think it has something to do with the connection between validout and validin[0..0]. Am I doing that right?
