MDesr2
7 years agoWe have an issue with our floating DSP perpetual licenses, the LMGRD as stopped running, see error message below
lmgrd is not running: License server machine is down or not responding. See the system administrator about starting the license server system, or make sure you're referring to the right host (see L...
HRZ
7 years agoBased on the error message, this seems to be an issue with your license server service. You should check the server on which you have installed the floating license and make sure the license server (lmgrd) is up and running and that port 1800 on that server is not blocked by anything.
