DShac
7 years agoWe bought a NIOS license ~10 months ago and suddenly the license stop working even that the license date is still valid until Nov 2019.
AnandRaj_S_Intel
7 years agoHi Dana,
Okay, If your NIC ID appear is wrong.
You may be able to fix this problem by adding a key in the Windows registry.
Use the Registry Editor (regedt32.exe) to view the following key in the registry: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters
Add the following registry value:
Value Name DisableDHCPMediaSense
Data TypeREG_DWORD -Boolean
Value 1
Reboot your computer for the change to take effect.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ts-index/lic.html#
Anand
