Waveform simulation vopt error
- 3 years ago
I was able to fix this problem by going into the simulation settings and add -suppress 12110 to the following line:
vsim -suppress 12110 -novopt -cI also had to give full write permissions(Full control to modify in folder properties) to folder C:\intelFPGA_lite\22.1std\questa_fse\intel\verilog\cyclonev
After these two steps the error no longer appeared
I’m glad that your problem has been solved, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
