AmirSina
4 years agoWaveform simulation generates no output
I installed Quartus Prime Lite 21.1.0.842 and Questa FPGA Starter 21.1.0.842 on Linux Mint 20.2.
I wanted to start by simulating a simple "AND2" circuit so created a project for MAX II device famil...
- 4 years ago
Solution below probably can help you out.
https://www.macnica.co.jp/business/semiconductor/support/faqs/intel/134162/
Hope it helps.
AmirSina
4 years agoBut when I do not remove -novopt this error happens:
I read somewhere that I should replace it with "+acc". but the result of functional simulation is still unknown.
ShengN_altera
4 years agoSolution below probably can help you out.
Hope it helps.
