10 years agoWaveform Editor - odd inversion
Hi, here is my code for a simple 8-bit counter with a decoded low signal for 1 clock period. signal Count: std_logic_vector(7 downto 0) := X"00"; if falling_edge(Bit_Clk_in) then C...
10 years ago --- Quote Start --- this should produce a low pulse every 32 clock cycles but when I run a functional simulation in Waveform Editor the signal WriteEn is actually displayed as a single high going pulse --- Quote End --- Perhaps you should replace the relational operator "equal" ( =24 ) by "less-or-equal" ( <=24 ).
