14 years ago
Warning: No paths found for timing analysis
I'm writing a spi module,just a receiver. Few lines,but many warnings.
The total logic elements is 0%.
Can an get a answer about how to result the problem?
Code:
module spi (input clk,
input cs,
input sdi,
output reg getdata,
output reg [7:0] recbuf
reg stsig = 0;
reg [3:0] reccount = 7;
always @(cs)
if(sdi) stsig = 0;
else stsig = 1;
always @(posedge clk)
begin
if(stsig && reccount<8)
begin
recbuf[reccount] = sdi;
reccount = reccount - 1;
end
else
begin
reccount = 7;
getdata = 1;
end
end
endmodule
Warnings:
Warning: Output pins are stuck at VCC or GND
Warning: Design contains 3 input pin(s) that do not drive logic
Warning: No exact pin location assignment(s) for 12 pins of 12 total pins
Warning: Following 9 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
    There might issue of tools here. While modelsim acepts your code it could be quartud thinks that stsig is assigned 0 and recbuf is assigned 7. you might better use init for that instead
    But
    always @(cs)
    if(sdi) stsig = 0;
    else stsig = 1;
    is used to identify a start of a data receiving and datas will be delivered many times however initial just run once.
    It's too late now,I'll go sleeping.
    Thank you for your advise.Enjoy a good afternoon!
