Warning: "No matching role found for nios2_gen2_0_custom_instruction_master_multi_xconnect"
- 6 years ago
Thank you for your patients, hope you are doing well.
After some investigation, per my understanding it seem that those interface (i.e. instruction pending and estatus) seems to be belonging to the master component, and possible just some signal mismatched between the master and slave.
Hence I would assume that the warning are just indicating that those interface in master are not being mapped to any slave, which we might be able to safely ignore.
Just to understand further, what are the purpose of using the FPH2 in the design?Warm Regards.
Hi.
Adding the crc custom instruction as described in chapter4 and then shown in figure 23 on page 51 did not help.
I also played with adding a custom_instruction_slave_translator between Nios and the fphw2 but that only introduced more similarwarnings.
It seems like the hint here is the _multi_xconnect which is an invisible thing in between somewhere...
Any more ideas?
/Nikolay
Warm Regards.
- NikoR5 years ago
Ok, thanks for your explanation.
The FPH2 is needed to support the floating point square root function....
- BoonBengT_Altera5 years ago
Moderator
Hope this message find you well and as clarification has been provided and none further clarification available, we would be closing the thread. If you have further queries, Please do post a response in the next 15 days.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
