I am facing similar problems.
I am trying to use the clocks provided on DE1 board from TerAsic (24MHz, 27MHz & 50MHz).
But My code doesn't work.
This is my code:
module LedBlink(CLOCK_24, LEDR);
input[1:0] CLOCK_24;
output [7:0] LEDR;
wire ovf;
reg out;
reg en, clk, clr;
reg[31:0] maxClks;
reg[7:0] div;
initial
begin
clk = 0;
div = 0;
out = 0;
maxClks = 1000000;
# 10 en=1;
# 10 clr=1;
# 20 clr = 0;
end
always @(posedge CLOCK_24[0])
begin
div = div + 1;
if(div == 24)
begin
clk = ~clk;
div = 0;
end
end
always @(posedge ovf)
begin
out = ~out;
end
assign LEDR[0] = out;
DelCtr del (ovf, en, clk, clr, maxClks);
endmodule
I had made use of the CLOCK_24 pin as a clock by using always construct.
But still I get the warning in quartus "No Clock Source Defined in Design".
Pls Help
