Warning# for the port width mismatch
- 3 years ago
Here's the list of all the error and warnings messages.
As of now, I don't think we have tcl command for suppress message. The available tcl commands are also available on the same webpage.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
So you know you have mismatches, but you're not seeing the warnings? Maybe the mismatched logic was optimized away, but you'd still see a warning.
- amildm3 years ago
Contributor
Exactly... I know there is a mismatch, but I don't see a warning.... How could it be so? Even a logic is optimized away, I still should see a warning...
In my specific case, I assigned the 32-bits port (output from ROM) to a single bit wire, but have not received any warning during the synthesis... How could it be so?
I'm suspecting that this warning is suppressed by mistake. How can I check this? Could be another reasons why Quartus do not alert about this mismatch?
