12 years agoHi,
I also have this problem. I'm using Quartus 13.0 and I'm targetting a Cyclone IV GX. I simplified my design to this:
escc_data_out <= "00010100";
ESCC_DATA <= escc_data_out when blink = '0' else "ZZZZZZZZ";
ESCC_DATA is also used as an input somewhere in the design. I get some warning for the whole bus: Warning (18029): Output pin "pre_syn.bp.ESCC_CTRL_ESCC_DATA_IN_0_" driven by bidirectional pin "ESCC_DATA" cannot be tri-stated
The RTL view seems correct: https://www.alteraforum.com/forum/attachment.php?attachmentid=8278 However, the post mapping view shows some strange things. Sometimes the blink signal is connected to the tri-state buffer enable pin, sometimes it is connected to the tri-state buffer input. If I don't use ESCC_DATA as an input, I don't have warnings anymore. Any idea ? Franck.
