11 years ago
Warning (10492): But it's a clocked process
I don't understand why I have this warning.
Warning (10492): VHDL Process Statement warning at top.vhd(890): signal "sLS" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Testchip_process : process (iRESETb, iMCK1)
begin
if iRESETb = '0' then
oCPGA68_A7 <= sLS;
elsif rising_edge(iMCK1) then
case stoto is
when toto2 =>
oCPGA68_A7 <= sLS;
when Toto1 =>
oCPGA68_A7 <= '0';
when others => null;
end case;
end if;
end process Testchip_process;
It's a clocked process, I don't need to have sLS in process sensitivity
1 Reply
    But you set the value of oCPGA68_A7 to sLS when you reset it. Hence you need it in the sensitivity list.
    Btw, this isnt a good thing to do. Reset value should be a fixed '0' or '1', or the synthesisor has to do some reset emulation, which isnt very good for timing.
