I'll try to explain more on what i want , depending on the input (sw) the register (sr) will assigned a collection of bits, also the signal (n) will be assigned an integer value which is the number of bits in the register, all of this will happen in the first process.
in the second process which is clocked i want it to shift the (sr) register for each rising edge clock (n) times.
here is what I've done:
counter : process(clk)
begin
if rising_edge(clk) then
if n/=0 then
if sr(0)='0' then
led <= "1111111";
elsif sr(0)='1' then
led <= "0111111";
end if;
n<=n-1;
sr<="0" & sr(15 downto 1);
end if;
end if;
end process;
end behavioral;
It's totaly wrong since two processes driving sr and n.
I know what I've done is stuped but I'm new to the vhdl and i came from another enviroment.
