17 years ago --- Quote Start --- It should be also possible to operate your RAM example with a bidirectional data port. The bidirectional IO cells have separate in- and output port at the FPGA side, all you need is an output enable signal with correct timing. This implies for synchronous solution, that the inout port must been set to 'Z' (= OE deasserted) one clock cycle before the input data can be latched. Alternatively, OE can be operated asynchronously from RW signal. --- Quote End --- Thanks.. Umm, I don't quite get it on the OE and RW part especially "OE can be operated asynchronously from RW signal".. Is OE different from RW..? Can you please advice how I can convert the code in Post# 16 (using seperate DataIn and DataOut port) into a code that is using bidirectional port..? Maybe, can you modify the existing code from Post# 16 as an example..? I understand better from examples.. Thanks and thanks again..
