10 years agoView routing in chip planner
Is there any way to view the routing in the chip planner? I would like to see which way a signal has been routed and how much routing resources are available at different locations. The "Routin...
10 years agoI don't like Routing Details and never use it, so not sure why it's not working, but have used Expand Connections many times in Cyclone V. I would be surprised if this were disabled for Lite but not sure. I always do a report_timing in TimeQuest on the path i'm interested in, right-click on the result and Locate -> Chip Planner. Then I double-click on the path in the Selection History(you may not have to do this for a single path, but you do if you locate multiple paths) and then click Expand Connections. I thought it worked after doing a Generate Fan-Outs but it's been many years since I've tried and before Cyclone V.
