15 years agoThanks for your help, but I have found the problem:
I might seems logical, but the SOPC builder must be clocked with the pixel clock, whereas I was using a faster clock. I'm a little bit surprised, because I thought the avalon bus needed a faster clock in order to transmit pixels and some others data in real time... and I thought that vid_clk at CVO was used to regenerate the correct video flow. (and that's why it worked fine with frame buffer). Thanks anyway!
