16 years ago
video and image processing
using video and image megawizard i m doing some video processing application i hve a block diagram of video processing,i didnt understand what is preprocessing block in that block diagram ,is it color space conversion rgb to y cb cr
or what. please help
    thanks 4 ur reply.ya this is lossless image compression but what is PREPROCESSING block.
    --- Quote Start ---
    --- Quote End ---
    preprocessing might be any processing taken before the actually process we are focusing on. The picture you attached probably want to stress on the compression part so the other processing which is not relevent to compression of the image is not told here (and put in a block called preprocessing).
    For example if the input is a NTSC video. It need to go for a few processing b4 compression take place. Maybe chroma resampling (YCbCr 4:2:2 -> YCbCr 4:4:4), color space conversion (YCbCr 4:4:4 to RGB), Scaling (720x480pixels -> 640x480pixels) and so on.
    thank i got it.
    --- Quote End ---
    --- Quote Start ---
    thank i got it.
    --- Quote End ---
    welcome.
    what kind of dev board u using right now?
    DE2? coz i saw you asking regarding it on another thread
