12 years ago --- Quote Start --- t2 will be just wired to t1. The assignment Y <= t2; being outside clock edge is firstly very uncommon. Secondly it implies that t2 drive Y whether t2 is assigned inside clock construct or occurs outside. We know that if clock edge occurs then t2 is assigned but if clock edge is not true then t2 must retains its value and this implies registered version of t2 to drive Y --- Quote End --- Yes you are right. I tried it too. In general my problem is to be able to create one solid process per logic entity with complex combinational logic that could also be exported out of the process as asynchronous signals to be used for other processes. In order to achieve that I suppose I have to use variables that get assigned outside the clocked if (but also read but not assigned inside the clocked if) and when I need to export them I can assign the variables-to-be-exported to signals but outside the clocked if. Another question is that maybe inside the clocked process I need to make a variable assignment. Is it possible to split the clocked if in two (so have two if(rising edge)) inside the same process and in between make asynchronous variable assignments?
process(clk)
variable t1 : std_logic;
variable t2 : std_logic;
begin
t1 := A and B;
if rising_edge(clk) then
Yb <= t1;
end if;
Y <= t1 XOR Yb;
t2 := A or B;
Yc <= t2 OR Y;
end if;
end process;
Is this mixture possible?
