12 years agoThe assignment C <= t1 ; reads t1 before t1 is assigned to, hence it infers a register
The assignment D <= t1 ; reads t1 after t1 has been assigned with 'A and B' hence D is fed with the combinatorial The assignment E <= t1 ; also infers a register, but in this case this is not visible as the compiler can re-use the previously inferred register (from C <= t1; ) Splitting the example over the three different assignments shows it better:-- test1------------------------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test1 is
Port(clk : in std_logic;
A : in STD_LOGIC;
B : in STD_LOGIC;
Y : out STD_LOGIC);
end test1;
architecture rtl of test1 is
begin
process(clk)
variable t1 : std_logic;
begin
if rising_edge(clk) then
Y <= t1; -- read first
t1 := A and B;
end if;
end process;
end rtl;
-- test2------------------------
library IEEE;
entity test2 is
A : in STD_LOGIC;
B : in STD_LOGIC;
Y : out STD_LOGIC);
end test2;
architecture rtl of test2 is
begin
process(clk)
begin
t1 := A and B; -- assign first
Y <= t1;
end if;
end process;
end rtl;
-- test3------------------------
library IEEE;
entity test3 is
A : in STD_LOGIC;
B : in STD_LOGIC;
Y : out STD_LOGIC;
Yb : out std_logic);
end test3;
architecture rtl of test3 is
begin
process(clk)
begin
t1 := A and B;
Yb <= t1;
end if;
Y <= t1; -- attempt to produce a comb output fails
end process;
end rtl;
-- all
library IEEE;
entity test is
A : in STD_LOGIC;
B : in STD_LOGIC;
Y1, Y2, Y3, Y3b : out STD_LOGIC);
end test;
architecture rtl of test is
begin
t1 : entity work.test1 port map(clk => clk, A => A, B => B, Y => Y1);
t2 : entity work.test2 port map(clk => clk, A => A, B => B, Y => Y2);
t3 : entity work.test3 port map(clk => clk, A => A, B => B, Y => Y3, Yb => Y3b);
end rtl;
producing this RTL Viewer image:
