11 years ago
VHDL Type Mismatch error
I have attached to this message two files that I am trying to compile (bus_relay.vhd and bcff.vhd).
The problem is that the file bcff.vhd which is the top level entity will not compile. It keeps giving me an error message of (Error (10381): VHDL Type Mismatch error at bcff.vhd(46): indexed name returns a value whose type does not match "std_logic_vector", the type of the target expression).
Could you please look at the two files for me and try to fix the bug.
Also I want to know if the current design has the bus_relay pass signals from IO1 to IO2 and vice versa. I am not sure that the signal is propagating properly. Would you look into this for me and fix the error.
Lewis.
    nice error, since the file only has 44 lines.
    [edit]
    you assign a single bit to a std_logic_vector and that is not valid.
    [/edit]
    indexing into an array gives you a single element of the array, which in this case is a std_logic. The component expects a std_logic_vector of length 1 (because N defaults to 1). So you need to pass it:
    LIN(0 downto 0)
    --- Quote Start ---
    LIN(0 downto 0)
    --- Quote End ---
    Hi.
    Thanks for the feedback.
    Could you give me an example in the form of the full source code.
