11 years ago
Vhdl traffic light counter
Please some help with this code, I dont know where is the problem, is giving me these errors:
Error: Node instance "TLong" instantiates undefined entity "OneShot"
Error: Node instance "TShort" instantiates undefined entity "OneShot"
here is the code...
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity TimerCircuits is
port (LongTrig, ShortTrig, Clk: in std_logic;
TS,TL : buffer std_logic);
end entity TimerCircuits;
architecture TimerBehavior of TimerCircuits is
component OneShot is
port (enable, Clk : in std_logic;
Duration : in integer range 0 to 25 ;
QOut : buffer std_logic );
end component OneShot;
signal SetCountLong, SetCountShort: integer range 0 to 25;
begin
SetCountLong <= 25;
SetCountShort <=4;
TLong:OneShot port map (enable=>LongTrig, Clk=>Clk, Duration=>SetCountLong, QOut=>TL);
TShort:OneShot port map (enable=>ShortTrig, Clk=>Clk, Duration=>SetCountShort, QOut=>TS);
end architecture TimerBehavior;
    Perhaps a stupid question:
    do you have a "OneShot.vhd" - File?
    I get the same Error if I remove the VHDL-File for a component from my project-folder.
