10 years agovhdl real time clock
Can you please help me with this task..I am having huge problems Design and implement a circuit on your DE-series board that acts as a real-time clock. It should display the minutes ...
10 years agolibrary ieee;
use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity real_time_clock is port (clk1 : in std_logic; seconds : out std_logic_vector(5 downto 0); minutes : out std_logic_vector(5 downto 0); miliseconds: out std_logic_vector(4 downto 0); hex0,hex1,hex2,hex3,hex5,hex5 (o to 6) ); end real_time_clock ; architecture Behavioral of real_time_clock is signal sec,min,mili : integer range 0 to 60 :=0; signal count : integer :=1; signal clk : std_logic :='0'; begin seconds <= conv_std_logic_vector(sec,6); minutes <= conv_std_logic_vector(min,6); miliseconds<= conv_std_logic_vector(mili,5); --clk generation.For 100 MHz clock this generates 1 Hz clock. process(clk1) begin if(clk1'event and clk1='1') then count <=count+1; if(count = 50000000) then clk <= not clk; count <=1; end if; end if; end process; process(clk) --period of clk is 1 second. begin if(clk'event and clk='1') then sec <= sec+ 1; if(sec = 59) then sec<=0; min <= min + 1; if(min = 59) then hour <= hour + 1; min <= 0; if(hour = 23) then hour <= 0; end if; end if; end if; end if; end process; end Behavioral; -------------------------------------bcd seven segment----------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY bcd7seg IS PORT ( bcd : IN STD_LOGIC_VECTOR(3 DOWNTO 0); display : OUT STD_LOGIC_VECTOR(0 TO 6)); END bcd7seg; ARCHITECTURE Behavior OF bcd7seg IS BEGIN PROCESS (bcd) BEGIN CASE bcd IS WHEN "0000" => display <= "0000001"; WHEN "0001" => display <= "1001111"; WHEN "0010" => display <= "0010010"; WHEN "0011" => display <= "0000110"; WHEN "0100" => display <= "1001100"; WHEN "0101" => display <= "0100100"; WHEN "0110" => display <= "0100000"; WHEN "0111" => display <= "0001111"; WHEN "1000" => display <= "0000000"; WHEN "1001" => display <= "0000100"; WHEN OTHERS => display <= "1111111"; END CASE; END PROCESS; END Behavior; THIS IS THE CODE..A LITTLE BIT NOT CLEAR, AND HAS STILL TO WORK ON IT. BUT BIGGEST PROBLEM IS THAT I DON'T KNOW HOW TO CONNECT OUTUPUTS TO SEVEN SEGMENT DISPLAY. I DON'T KNOW HOW TO CONNECT FOR EXAMPLE SECONDS TO HEX4,5....AND HOW TO CHANGE MINUTES USING SW7 DONWTO O
