10 years ago
VHDL problem
Hi everyone,
I'm a new user of FPGA.
I have 2 LEDs and a clock of 32KHz.
So I wanna light up LED1
then light off LED 1 and light up LED2.
Im trying to do something in VHDL, but it seems it's nonsense what I've done
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_SIGNED;
use IEEE.STD_LOGIC_UNSIGNED;
use IEEE.STD_LOGIC_ARITH.ALL;
ENTITY TP4LED IS
PORT (
clock : IN std_logic;
s1: OUT std_logic;
s2: OUT std_logic
END TP4LED;
ARCHITECTURE behavior OF TP4LED IS -- fonctionnement d'une bascule D
signal count : integer(10 downto 0);
BEGIN
PROCESS (clock) -- liste de sensibilité
BEGIN
count <= '0';
s1<='1';
s2<='0';
if(clock'event and clock='1')then
count <= count + 1;
if (count = '9') then
s1<='0';
s2<='1';
count<=0;
end if;
end if;
END PROCESS;
END behavior;
In addition, I have this mistake that I don't know how to resolve it
Error (10380): VHDL error at TP4LED.vhd(24): integer type is used but not declared as an array type
I know it might be an easy question. Could anyone help me please
thank you very much
Bo
1 Reply
    integer is not an array type, so you cannot use it like and array. Your count signal declaration says you want 11 integers. If you wanted a single integer with 11 bits, you should use the unsigned type (before you do this - delete the non-standard std_logic_unsigned/signed and std_logic_arith libraries from your library list - otherwise you're going to get all sorts of conflicts).
    You need:
    signal count : unsigned(10 downto 0);
    secondly, '9' is a character, not an integer value. change it to
    if count = 9 then...
    Finally, do not do assignments outside of the clocked part of the process.
