I have a very similar problem but I don't know how to find the solution. I compile,synthesize in Precision and I do the place and route in QuartusII. I want to simulate the whole project with the .vho and .sdo files in modelsim. I have written a testbench and when I tried to do the simulation I have the next errors:
# ** Error: (vsim-SDF-3250) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo(35): Failed to find INSTANCE '/testbench/iCLK_50_ibuf/asynch_inst'.
# ** Error: (vsim-SDF-3250) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo(44): Failed to find INSTANCE '/testbench/\iCLK_50~clkctrl\'.
# ** Error: (vsim-SDF-3250) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo(53): Failed to find INSTANCE '/testbench/\iCLK_50~clkctrl\/extena0_reg'.
# ** Error: (vsim-SDF-3250) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo(68): Failed to find INSTANCE '/testbench/\iSWITCH_ibuf_0_\/inreg_D_mux'.
# ** Error: (vsim-SDF-3250) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo(77): Failed to find INSTANCE '/testbench/\iSWITCH_ibuf_0_\/input_reg'.
# ** Warning: (vsim-SDF-3432) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo: This file is probably applied to the wrong instance.
# Ignoring subsequent missing instances from this file.
# ** Warning: (vsim-SDF-3440) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo: Failed to find any of the 23 instances from this file.
# ** Warning: (vsim-SDF-3442) C:/Documents and Settings/Jose/Escritorio/Prueba_VHDL/Prueba_temp_5/simulation/modelsim/PROBA_vhd.sdo: Try instance '/testbench/dut'. It contains all instance paths from this file.
¿If anybody can suggest any possible solution?
Many thanks
