VHDL Package not detected by Modelsim
Hi all ,
I am using Quartus Prime ver 16.0 for compilation of my vhdl project files , the project compiles fine without any errors , but when i start simulation the Modelsim cantt seem to find my package file .
Modelsim version : ModelSim ALTERA STARTER EDITION 10.4d
Although i made a "work" folder myself and pasted the vhdl package in it , but still no effect , then i copied the folder and pasted it in D:\Quartus_projects\i2c_audio_Fir_filtr1p1\simulation\modelsim
Still i get this error :
# vcom -93 -work work {D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd}
# Model Technology ModelSim ALTERA vcom 10.4d Compiler 2015.12 Dec 30 2015
# Start time: 15:50:44 on Mar 07,2022
# vcom -reportprogress 300 -93 -work work D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Loading package std_logic_arith
# -- Loading package STD_LOGIC_UNSIGNED
# -- Loading package NUMERIC_STD
# ** Error: (vcom-11) Could not find work.audio_codeci2c_pkg.
# ** Error (suppressible): D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(11): (vcom-1195) Cannot find expanded name "work.audio_codeci2c_pkg".
# ** Error: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(11): Unknown expanded name.
# ** Error: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(13): VHDL Compiler exiting
# End time: 15:50:44 on Mar 07,2022, Elapsed time: 0:00:00
# Errors: 4, Warnings: 0
# ** Error: C:/altera_lite/16.0/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./Audio_FIR_filter_run_msim_rtl_vhdl.do line 74
# C:/altera_lite/16.0/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd}"
In my Top vhdl file and in my testbench i have declared it like this :
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- USE IEEE.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
use ieee.math_real.all;
USE std.textio.ALL;
Library work;
use work.audio_codec_i2c_pkg.all;
Any clue why modelsim is not able to open it ???
Spelling difference? audio_codec_i2c_pkg vs. audio_codeci2c_pkg
- sstrell
- ZKhan1
Thanks i got rid of that error , but now i am getting this error :
# -- Loading package audio_codec_i2c_pkg
# -- Compiling entity tb_audio_ctrl_Top
# -- Compiling architecture testing_audio of tb_audio_ctrl_Top
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(54): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(55): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# ** Warning: D:/Quartus_projects/i2c_audio_Fir_filtr1p1/source/tb_audio_ctrl_Top.vhd(58): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# End time: 14:35:41 on Mar 08,2022, Elapsed time: 0:00:00
# Errors: 0, Warnings: 5
# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs="+acc" tb_audio_ctrl_Top.vhd
# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive_ver -L cycloneive -L rtl_work -L work -L Fir_left_ch -voptargs=""+acc"" tb_audio_ctrl_Top.vhd
# Start time: 14:35:41 on Mar 08,2022
# ** Error: (vsim-19) Failed to access library 'tb_audio_ctrl_Top' at "tb_audio_ctrl_Top".
# No such file or directory. (errno = ENOENT)
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./Audio_FIR_filter_run_msim_rtl_vhdl.do PAUSED at line 76 - sstrell
Can you show the code lines from the file that are mentioned as having issues?
- BikshuNaik
I have generated some IPs in Quartus Prime Pro edition software and due to some reason I am trying to simulate the design in Modelsim -INTEL FPGA Starter edition and I am facing errors like this:
** Error: (vsim-3033) ../.../IP_Folder/pll_div_by2/altera_iopll_1931/sim/stratix10_altera_iopll.v(498): Instantiation of 'fourteennm_iopll' failed. The design unit was not found.
** Error (suppressible): (vsim-19) Failed to access library 'fourteennm_ver' at "fourteennm_ver".
# No such file or directory. (errno = ENOENT).so can someone please help me? what is my mistake and how to solve this.
- ZKhan1
See attached test bench and do file as well .
- ZKhan1
Testbench :
-- Testbench for the i2c_audio_ctrl_Top.vhdLIBRARY ieee;
USE IEEE.std_logic_arith.ALL;Library work;
USE work.audio_codec_i2c_pkg.All;ENTITY tb_audio_ctrl_Top IS
END tb_audio_ctrl_Top;ARCHITECTURE testing_audio OF tb_audio_ctrl_Top IS
COMPONENT i2c_audio_ctrl_Top
port (
CLOCK_50 : in std_logic;
PUSHB : in std_logic_vector ( 3 downto 0 );
LED : out std_logic_vector ( 3 downto 0 );
SW : in std_logic_vector ( 17 downto 0 );
LEDR : out std_logic_vector ( 17 downto 0 );
LEDG : out std_logic_vector ( 7 downto 0 );
GPIO : out std_logic_vector ( 35 downto 0 ); -- 40-pin Connector
I2C_SCLK : out std_logic;
I2C_SDAT : inout std_logic;
--audio codec ports
AUD_ADCDAT : in std_logic;
AUD_ADCLRCK: out std_logic;
AUD_DACLRCK: out std_logic;
AUD_DACDAT : out std_logic;
AUD_XCK : out std_logic;
AUD_BCLK : out std_logic
END COMPONENT; - sstrell
I'm guessing the simulator doesn't like your use of "us" and "ms" right after a value without a space.
- ZKhan1
Thanks again for pointing that out , i did get rid of those warnings , but i still get that error :
- ZKhan1
With in Modelsim in the above attached pic , i noticed that Modelsim only has "Fir_left_ch" , although in vhdl top file i have two Fir ip included one for left and other for right channel . Anyway i right clicked on the tb in the work folder and forced compiled it , and it successfully compiled it and then simulated the tb and it worked .
- ZKhan1
I still want to get rid of this annoying error which pops up when i start simulating from Quartus i.e "# ** Error: (vsim-19) Failed to access library 'tb_audio_ctrl_Top' at "tb_audio_ctrl_Top".
Why do i have to force compile and simulate the tb
- SyafieqS
Ahmed,
You probably need to look at below KDB related to your issue
