10 years agoVhdl jpeg decoder
Hi, I am working on a project where I need to implement a JPEG decoder to decode the JPEG output (1080p) of the camera (model: OV5642). My FPGA is DE1-SoC Cyclone V. I have been able to implement a j...
10 years agoOk. You should sure that you saturated in c code optimization) no any suggestions
If as you mentioned and you use appropriate data types and computing based on tabulated values You can verify according the standard optimization for loops, multiplication and even try some techniques for high performance computing cluster I think if it applicable increasing speedup of algorythm I read some reports about parallel processing for jpeg ls format But unfortunately I can't advise ready made for your problem
