10 years agoVhdl jpeg decoder
Hi, I am working on a project where I need to implement a JPEG decoder to decode the JPEG output (1080p) of the camera (model: OV5642). My FPGA is DE1-SoC Cyclone V. I have been able to implement a j...
10 years ago --- Quote Start --- Have you optimized c code? And where is the bottleneck? If you profiled your decoder you should know dataflow path. --- Quote End --- Yes, I know my way around the c code and was able to optimize it. However, the thing is that the clock frequency of the hard processor system is just not enough after a certain point. For example, after optimizing the code, I have achieved 15 fps. So, since I need 30 fps, I turned my direction to finding a vhdl open source for jpeg decoding that can be run on an Altera board. Do you know anything like that? If there is not any, I will have to stick with the c code, of course. Thank you for your response.
