10 years agoVhdl jpeg decoder
Hi, I am working on a project where I need to implement a JPEG decoder to decode the JPEG output (1080p) of the camera (model: OV5642). My FPGA is DE1-SoC Cyclone V. I have been able to implement a j...
10 years ago --- Quote Start --- If its not on opencores, then it's not likely to be free. Jpeg decoding isn't something you usually need on fpga, as a single image isn't exactly a lot of data. Fpgas address much better at stream processing. The Xilinx code you've found might be portable to altera. Otherwise you'll have to write your own core. --- Quote End --- I am sorry I did not make it clear that I am using the camera at video mode. So, in fact, I have a stream of jpeg images (30 fps) that I need to decode. My advisor suggested me to move the jpeg decoder to vhdl, which I have problems with. Thank you for your response.
