9 years agoVHDL help for using built in Comparators
Hi all, when I try to use Quartus built in integer comparators I am experiencing some problem. I am trying to sort 64 numbers stored in a 2 port RAM. When I input the addresses and get back 2 ...
9 years agoThanks for the help.
I mean the comparison result select data to the corresponding port of mem2. Let's say I input the two numbers, which coming out from mem1, into comparator at clock cycle 1. Then the comparison result will come out at clock cycle 2. And I use IF statement to choose the smaller number and send it to port_a at clock cycle 2. But what the IF statement has picked is the comparison result at clock cycle 1 but not clock cycle 2. The process is like follows:
merg: PROCESS (clock, merg_en)
---some variables ----
IF (rising_edge(clock)) then
IF (merg_en = '1') then
------------- send address to m1 to get number ---------------------
if (rd_adr_a < 62) then
m1_rden_a <= '1';
m1_rden_b <= '1';
m1_wren_a <= '0';
m1_wren_b <= '0';
m1_adr_a <= std_logic_vector(to_unsigned(rd_adr_a, 7));
m1_adr_b <= std_logic_vector(to_unsigned(rd_adr_b, 7));
rd_adr_a := rd_adr_a + 2;
rd_adr_b := rd_adr_b + 2;
else
m1_rden_a <= '0';
m1_rden_b <= '0';
end if;
-------------- get m1 feedback, compare, and store to m2 ------------------
if (wr_adr_small < 62) then
if (rd_delay < 3) then -- 3 clock cycle delay to wait m1 send back data
rd_delay := rd_delay + 1;
else
cp_dataa <= m1_q_a;
cp_datab <= m1_q_b;
if (cp_delay < 1) then -- 1 cc omparator delay to wait comparator give result
cp_delay := cp_delay + 1;
else
if (cp_eq = '1') then
m2_rden_a <= '0';
m2_rden_b <= '0';
m2_wren_a <= '1';
m2_wren_b <= '1';
m2_data_a <= cp_dataa;
m2_data_b <= cp_datab;
m2_adr_a <= std_logic_vector(to_unsigned(wr_adr_small, 7));
m2_adr_b <= std_logic_vector(to_unsigned(wr_adr_big, 7));
wr_adr_small := wr_adr_small + 2;
wr_adr_big := wr_adr_big + 2;
elsif (cp_gr = '1') then -- q_a > q_b
m2_rden_a <= '0';
m2_rden_b <= '0';
m2_wren_a <= '1';
m2_wren_b <= '1';
m2_data_a <= cp_datab;
m2_data_b <= cp_dataa;
elsif (cp_ls = '1') then -- q_a < q_b
m2_rden_a <= '0';
m2_rden_b <= '0';
m2_wren_a <= '1';
m2_wren_b <= '1';
else
end if;
end if; -- end delay1cc
end if; -- end delay3cc
end if; -- end rd_adr_a
end if; -- end merg_en
-------- some other things ----------
end if;
