11 years agoVHDL FILE_OPEN does not return correct status in Quartus
I have a procedure in VHDL that reads a line from file and is supposed to assign signal values based on individual characters of the line. The problem i am facing is that my FILE_OPEN statement seems...
11 years ago --- Quote Start --- Any alternate for this ? I am trying to simulate an instruction sequence that i have written in file. The contents of the file looks as follows:
20020005
2003000c
2067fff7 Is there any way i can read these values and assign them to signals, or changing the tool is the only option ? --- Quote End --- If it is only simulation, then you can use code similar to that in the original post to load the instructions.
