Altera_ForumHonored Contributor12 years agoVHDL expression error ( different data width) Hello, I am not expert in VHDL, and I got stuck with this problem. In the original code 'fifo_data_out' was defined as 24 bit (INPUT_DATAWIDTH = 24) and the compilation was successful SI...Show Moremultiple-attachments.zip390 KB
Altera_ForumHonored Contributor12 years agoI saw those zeros as Hex value......you are right. Thanks :)
Recent DiscussionsCompile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusIIConnection bit order between hierarchy
