The main problem you have is you're using std_logic_vectors for arithmatic. They are designed to just represent a collection of bits. They have no real meaning as unsigned or signed, and could be either.
If you scrap std_logic_signed package, and instead use ieee.numeric_std instead, you get access to types unsigned and signed.
So in your case, you could write your entity:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity SubAdder is
port( worda: in signed(7 downto 0);
wordb: in signed(7 downto 0);
addsub: in std_logic;
res: out signed(7 downto 0);
overflow: out std_logic
end SubAdder;
architecture Func of SubAdder is
begin
process (worda,wordb,addsub)
begin
if addsub = '1' then
res <= worda + wordb;
else
res <= worda - wordb;
end if;
end process;
end Func;
