Humm, thank you for the replies :p!
I am trying to make a 8-bit signed adder (then I will make it a sub/adder), but I guess its working as a unsigned one, look at my code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
entity SubAdder is
port( worda: in std_logic_vector (7 downto 0);
wordb: in std_logic_vector (7 downto 0);
addsub: in std_logic;
res: out std_logic_vector (7 downto 0);
overflow: out std_logic
end SubAdder;
architecture Func of SubAdder is
begin
process (worda,wordb,addsub)
begin
res <= worda + wordb;
end process;
end Func;
But I guess its not working for negative numbers, should negative numbers be on the 2-complements form? Or the 8th bit '1' representing it as negative (+1)? I tried 81 + 01, it outputted 82 :p
Thank you again :)
