8 years agoVHDL Error. Type of identifier does not agree with it's usage
library ieee;
use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std; entity multi_main_file is port( Clock,reset: in std_logic ); end multi_main_file; architecture beh of multi_main_file is component pc_adder_mul is port( add_in: in std_logic_vector(31 downto 0); control: in std_logic; add_out: out std_logic_vector(31 downto 0) ); end component; component and1 is port( and_in1: in std_logic; and_in2: in std_logic; and_out: out std_logic ); end component; component alu_control is port ( instr_5_0: in STD_LOGIC_VECTOR (5 downto 0); alu_op: in STD_LOGIC_VECTOR (1 downto 0); alu_control_out: out STD_LOGIC_VECTOR (2 downto 0) ); end component; component control_unit is port( Instruction: in std_logic_vector(5 downto 0); Reg_Dest: out std_logic; Branch: out std_logic; MemRead: out std_logic; MemToReg: out std_logic; ALUOp: out std_logic_vector(1 downto 0); MemWrite: out std_logic; ALUSrc: out std_logic; RegWrite:out std_logic --Jum: out std_logic; ); end component; component data_memory is port( MemWrite: in std_logic; MemRead: in std_logic; Clock: in std_logic; address:in std_logic_vector(31 downto 0); Write_Data: in std_logic_vector(31 downto 0); Read_Data: out std_logic_vector(31 downto 0) ); end component; component instruction_memory is port( Instruction_Addr: in std_logic_vector(31 downto 0); Instruction: out std_logic_vector(31 downto 0) ); end component; component alu is port( A: in std_logic_vector(31 downto 0); B: in STD_LOGIC_VECTOR(31 downto 0); alu_control: in STD_LOGIC_VECTOR(2 downto 0); result: out STD_LOGIC_VECTOR(31 downto 0); zero_flag: out STD_LOGIC ); end component; component program_counter is port( Clock: in std_logic; PC_in: in std_logic_vector(31 downto 0); PC_out: out std_logic_vector(31 downto 0) ); end component; component register_file is generic( Data_width:integer:=32; Address_width:integer:=5 ); port( Read_Reg_1: in std_logic_vector(Address_width-1 downto 0); Read_Reg_2: in std_logic_vector(Address_width-1 downto 0); Write_Reg: in std_logic_vector(Address_width-1 downto 0); Write_Data: in std_logic_vector(Data_width-1 downto 0); Read_Data_1: out std_logic_vector(Data_width-1 downto 0); Read_Data_2: out std_logic_vector(Data_width-1 downto 0); Mem_Write: in std_logic; Clock: in std_logic ); end component; component shift_left_module is port ( l_sh_in: in STD_LOGIC_VECTOR (31 downto 0); l_sh_out: out STD_LOGIC_VECTOR (31 downto 0) ); end component; component sign_extender is port( exten_in: in STD_LOGIC_VECTOR (15 downto 0); exten_out: out STD_LOGIC_VECTOR (31 downto 0) ); end component; component adder1 is port( Add_in1: in std_logic_vector(31 downto 0); Add_in2: in std_logic_vector(31 downto 0); Add_out: out std_logic_vector(31 downto 0) ); end component; component mux_32 is port ( in1: in std_logic_vector(31 downto 0); in2: in STD_LOGIC_VECTOR(31 downto 0); mux_select: in STD_LOGIC; mux_out: out STD_LOGIC_VECTOR(31 downto 0) ); end component; component mux_5 is port ( mux_select: in STD_LOGIC; in1: in std_logic_vector(4 downto 0); in2: in STD_LOGIC_VECTOR(4 downto 0); mux_out: out STD_LOGIC_VECTOR(4 downto 0) ); end component; component mux_alu is port ( in1: in std_logic_vector(31 downto 0); in2: in STD_LOGIC_VECTOR(31 downto 0); in3: in std_logic_vector(31 downto 0); mux_select: in STD_LOGIC_vector(1 downto 0); mux_out: out STD_LOGIC_VECTOR(31 downto 0) ); end component; component or1 is port( in1: in std_logic; in2: in std_logic; out1: out std_logic ); end component; component mem_data_reg is port( clock: in std_logic; in1: in std_logic_vector(31 downto 0); out1: out std_logic_vector(31 downto 0); end component; component shift_left_26 is port ( l_sh_in: in STD_LOGIC_VECTOR (25 downto 0); l_sh_out: out STD_LOGIC_VECTOR (27 downto 0) ); end component; component instr_mem is port ( datain: in STD_LOGIC_VECTOR (31 downto 0); irwrite: in STD_LOGIC; irout: out std_logic_vector(31 downto 0) ); end component; component tempreg is port ( datain :in std_logic_vector(31 downto 0); clk :in std_logic; dataout out std_logic_vector(31 downto 0); end component; component mux_aluop is port ( in1: in std_logic_vector(31 downto 0); in2: in std_logic; in3: in std_logic_vector(31 downto 0); in4: in std_logic_vector(31 downto 0); mux_select: in STD_LOGIC_vector(1 downto 0); mux_out: out STD_LOGIC_VECTOR(31 downto 0) ); end component; signal s0,s1,s2,s3,s4,s5,s6,s8,s9,s10,s11,s12,s13,s14,s15,s17,s18: std_logic_vector(31 downto 0); signal s16: std_LOGIC_VECTOR (31 downto 0); signal c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c14,c15,c16: std_logic; signal d1: std_logic_vector(4 downto 0); signal c11,c12,c13: std_logic_vector(1 downto 0); signal c17:std_logic_vector(3 downto 0); signal w1: std_logic_vector(27 downto 0); begin s18(27 downto 0) <= w1(27 downto 0); s18(31 downto 28) <= s1(31 downto 28); mul1: pc_adder_mul port map(s0,c15,s1); mul2: mux_32 port map(s1,s16,c3,s2); mul3: data_memory port map(c5,c4,clock,s2,s13,s3); mul4: instr_mem port map (s3,c7,s5); mul5: mem_data_reg port map(clock,s3,s4); mul6: register_file port map(s5(25 downto 21),s5(20 downto 16),d1,s8,s11,s10,c9,clock); mul7: mux_5 port map(c8,s5(15 downto 0), s5(20 downto 16),d1); mul8: mux_32 port map(s4,s16,c6,s8); mul9: sign_extender port map(s5(15 downto 0),s9); mul10: shift_left_module port map(s9,s17); mul11: tempreg port map(s11,clock,s12); mul12: tempreg port map(s10,clock,s13); mul13: shift_left_26 port map(s5(25 downto 0),s18); mul14: mux_32 port map(s12,s1,c10,s6); mul15: mux_alu port map(s13,s9,s17,c11,s14); mul16: alu_control port map(s5(5 downto 0),c17,c12); mul17: alu port map(s6,s14,c17,s15,c16); mul18: tempreg port map(s15,clock,s16); mul19: mux_aluop port map(s15,s16,s18,c13,s0); end beh;mul19: mux_aluop port map(s15,s16,s18,c13,s0); error at s16.
it says type of identifier doesnot agree with it's usage.
thanks in advance. help appreciated !
