I am not totally ok with you. Unsigned is std_logic but with a particular signification. You can assigned an unsigned to a std_logic (I discovered it just now, I did not think that it was possible), but not an unsigned to a std_logic_vector. Here there is an example, with this code :
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Example is
port
clock : in std_logic;
reset : in std_logic;
outputScalar : out std_logic;
outputVector : out std_logic_vector(9 downto 0)
end Example;
architecture arch_Example of Example is
signal counter : unsigned(9 downto 0);
begin
outputVector <= counter;
outputScalar <= counter(0);
process(reset, clock)
begin
if reset = '1' then
counter <= (others => '0');
elsif rising_edge(clock) then
counter <= counter + 1;
end if;
end process;
end architecture arch_Example;
Quartus will give you the following error :
--- Quote Start ---
Error (10476): VHDL error at Example.vhd(22): type of identifier "counter" does not agree with its usage as "std_logic_vector" type
--- Quote End ---
And you have to use the following code
library ieee;
entity Example is
port
end Example;
begin
outputVector <= std_logic_vector(counter);
begin
if reset = '1' then
end if;
end process;
But now, I am ok with the fact that he did not get an error, but anyway it is always better to be coherent between signal and use unsigned only if it is needed.
