Put T in the sensitivity list will not change the behaviour, but it is possible that the logic generated be different, I am not sure on it. You can check that with the RTL viewer in Quartus after compilation.
About the counter, there are two things. The first is that I am not sure if you can put equation instead of a signal as a parameter of port map. I would advise to create a signal for inputs of each TFF, and moreover this will simplify the equation. Here you have an example :
signal T : std_logic_vector(16 downto 0);
T(0) <= enable;
T(1) <= Qout(0) & T(0);
T(2) <= Qout(1) & T(1);
myTFFi : entity work.myTFF port map( T(i), clk, rst, Qout(i));
Secondly, you declare Qout as unsigned, whereas output of TFF is std_logic, it is not coherent (Quartus did not give you an error about this ?) You can declare Qout as std_logic_vector, it is not needed to use unsigned since you don't make arithmetic operation on it.
