16 years ago
VHDL Configuring generics
i have written a VHDL Model wich is configured by a set of generics in the top level entity. The Ports of the model are always the same. No i want to give a number to every set of generics, and choose the generic set by only changing the number in the code. What is the right VHDL keyword?
For example:
Set# 1:
Generic Map(
gen1 := 17
gen2 := 22
gen3 := 14
Set# 2:
Generic Map(
gen1 := 1
gen2 := 4
gen3 := 12
Now i only want to change the set# to select the generics.
Thanks in advance,
paddy
    As said, you can use a constant array
       TYPE GEN_ARRAY IS ARRAY (1 TO 6,1 TO 3) OF INTEGER;
       CONSTANT gen : GEN_ARRAY :=
       ((2,3,3),
        (1,2,4),
        (2,2,1),
        (1,3,4),
        (1,5,4),
        (2,2,5));
       generic map
       ( gen1 =>gen(gen_sel,1), gen2 => gen(gen_sel,2))
    many thanks to all. I tried the solution with the "generic record" and it works very fine. Now i have defined all sets of generics in the array and select one by only changing the set#. Thats what i wanted!!!
    Thanks again
    Paddy
