--- Quote Start ---
The IF GENERATE works, that is the solution i used before askink here. But there are 40 sets of generics, and i do not want to set the Port Map in every generate....So i am searching for a better solution.
--- Quote End ---
you dont have to. If the port map is the same (like you say) you just do this:
my_ents_gen : for i in 0 to 39 generate
my_ent : my_entity
generic map (
gen0 => GENERICS(i)(0),
gen1 => GENERICS(i)(1),
gen2 => GENERICS(i)(2),
..etc
port map (
--Do 1 port map once
end generate my_ents_gen
you only write the code out once.
