10 years agoVHDL Code Help
Hi everyone, I'm new FPG and VHDL, I am trying write this code: Pushing a SW1 will turn on the 4 LEDs on the board one by one from up to down every 2 seconds until all LEDs are lit. Y...
10 years ago) why do not start reading books, look for reference design, surf Altera website for university program materials
what behaviour do you expect? 1. Switch -> will it be simple like light switcher? what about bouncing? do you need register? 2. LEDs -> could you draw a time-diagram for yourself? 3. timer -> implement it later, on the start of project rely on LED switch every clock-cycle. You should use clock your scheme won't be pure combinatorial. If you able to answer this question you probably write code. So others can take a look .
